does anyone have a problem with their A/C humidity water pouning in the cab and not out of the drain. also where is the drain located i can not find it anywhere. maybe i haven't looked hard enough. any way help would be appreciated.
on my ,03 it is stickin' out of the firewall....yours maybe plugged and going inside?:popcorn:
i don't think it is because it only does it when the A/C is on. i can leave the A/C off and it will go away. at first i had 4 cracks in my cab and i could shoot water through the back glass where the cab is welded together. my carpet is ruined. do you think it still can be a heater core?
If the heater core was leaking it wouldn't be water it would be radiator fluid.... assuming you use anti-freeze or something similar.
