1 - 4 of 4 Posts
I have an 2004 1 ton and the a/c is blowing hot on the passenger side and cold on driver side, i only have the one controler for both sides but i`m prewired for the dual setup, getting hot in az
i have the same problem on my 03 3500
and i checked the freon and the gage said it was good i think one of the flow flaps in the ducting is not opening ?
I had this happen on mine, and checked the freon level with a walmart freon kit gauge, and it said it was fine. It started to blow cold out of both vents after that, then the amount of air that was coming out of the vents was minimal. I pulled the fan motor (passenger side floor board, 3 screws) and felt up in there; and the recirculation door was blocking the air flow. I pulled this out through the fan opening, and have not had any issues since. This maybe something that may assist you.
1 - 4 of 4 Posts
