2006 Dodge with cummins. Bought this truck last winter and the a/c seemed the be working fine. Now that its warm the air from the driver vents is blowing warm and the air from the passenger vents are ice cold. Tried defrost vents and floor and seem to have the same problem. Have researched this problem and found that certain vent doors in the system can cause the problem but every case I have read about is the driver side cold and the passenger side warm. I checked the freon and is currently the correct level. Also noticed a line at the compressor will form ice then defrost when truck is shut off. I am pretty good at mechanics - do not want to get ripped at the a/c shop. Any suggestions to the root of the problem would be greatly appreciated - Texas heat is a killer. Thanks, Nathan
