I picked up a wrecked 99 recently. It was a good deal and it turned over and started, ran fine so I had to get it. It's been sitting about a month or 2 while I sourced parts to fix the front end. I start and let it run once a week or so for a little while to keep everything flowing, move it so it doesnt kill grass etc. Last time it ran for about 5 seconds then cut off. Long story short the truck has the platinum FASS on the rail behind the cab and it wasn't running. The relay for it is powered off the battery and the relay coil gets 12v from ECM supply to the stock LP. There's no 12v coming out of the ECM while engine cranking or anything so it sucked the system dry and i played hell priming the system and bleeding the HP side of the system. I got it running jumping the relay, using hand pump to prime the FASS all the way up to the HPP then cracked injector lines loose to bleed the HP side and after about 30 minutes it was running then the dryrotted blue hoses that came with the FASS back to the fuel filler started spewing fuel but luckily i had enough 3/8" hose to fix it.
So main question, I've heard you can bypass the ECM LP driver circuit by supplying 12v off the ignition switch RUN position to the fass relay. Has anyone noticed any downsides to this?
