OK, I have read alot of threads on here and to get to the point my truck just won't start. Cranks forever, but won't start. Looking for suggestions. So heres the story....
Thought the VP44 Pump finally died, when changing fuel filter, i always just fill the canister with fuel after replacing it and it always starts right up. This time it did not. but just as it fired once i turned off the key and has never fired again.
It is a 99' 2500, 4x4, Cummins, Manual Transmission.
So i replaced the VP44 with a new Integrity Pump from Thoroughbred Deisel and while at it i installed a new Air Dog FP100 Lift Pump.
Still will not start.
Here is what i have checked and can say...
1) The Lift pump works fine, getting 15psi (have guage on it) and it is cycling correctly.
2) I have power at pin 7 of the VP44 (12.23V)
3) I have ground at pin 6 of the VP44
4) Pin 5 does not have power during run or start position of key, but doesn't have power for the 3 seconds it should when the key is turned off either.
5) I have switched the fuel pump relay with the horn relay
6) Bigggy,,, I have NO codes.
7) I have cracked 3 of the injectors (1, 3, 4) and I get no fuel out of any of them
8) I have completely removed the old filter/seperator canister, since put in the Air Dog.
9) I have a new Overflow Valve on the return line that came with the new pump.
10) i have the Super Chip Mileage XP program in it, so i cleared the program and reloaded it.
11) I have fuel at the VP44 from the pump, i pulled the quick disconnect from the Liftpump and it filled a canister before the pump stopped cycling.
Only thing i have not tried is to power pins 6 & 7 of te VP44 with the connector removed and see if it would start and idle and have not tried shooting ether down the intake. I will try this tomorrow.
Thanks for reading and hope you know something i don't
