1 - 2 of 2 Posts
Hey guys so I WAY OVERPAID for this truck.,.. as the title says u know what it is.... so ill be including a picture with all the codes it has.... im assuming its the PCM on passenger firewall... any thoughts would be great thank you......
SO what happened.... I was stopped pulling into a parking lot and right when i was about to go the engine just shut off... so i hurridly put it in park and then restarted it threw it in drive and pulled into the lot...... i parked.....i went inside got what i was getting...came out and started the truck up..... it idled up to about 1200...down to 700ish then 1000 then died... tried it a few more times and it kept doing it.....decided to just have it towed the rest of the way to the mechanic shop(where i was headed anyways) soooo...guy has it about 2 weeks....tells me the fuel pressure is weak but didn't give me a number (psi) and tell me i need to replace the vp-44 and that its gonna be 3500$$ parts labor and sheet plus 500 for the water pump coolant and diagnostic... sooo yeah.... idk WTF im gonna do ... im almost positive its not the vp-44 because ive got all these codes you'll see in the picture ... please help me someone.... I live in California
NEVERMIND the picture wont load The codes are in order how they show..
p02160-Fuel timing error
P1698- No trans Bus messages
P0380- Glow plug/heater Circuit A
P0382- Glow plug/heater Circuit B
P1291- Heated Air Intake
P01698- No trans bus messages
P0216- Fuel Timing Error
First buy a set of sockets and drag it home. and get a cheap scan tool from Harbor or Autozone. Tow it home.
Second 0216 he is correct and the VP44 is toast.
A water pump is 50 bucks plus coolant and takes you an hour with a 3/8 socket set. Does it leak?
$3500 at a shop is almost reasonable for a VP and lift pump both.
If you do it your self you can do a VP for 1100 to 1700 depending on source.
A bad lift pump could be the source of the VP damage, but would have to know pressrue to be sure, becasue it is not always the case. A new lift pump can be done for anywhere from $100(modified aftermarket) to stock for $200, to $1000 for custom aftermarket. All doable by you.
1698 is also a bad VP probably or wiring.
Most all other codes are related to grid heaters that it appears may have been deleted?
Where in CA are you? I am near Yuba City.
1 - 2 of 2 Posts
