1 - 12 of 12 Posts
Ok fellas a guy brought me his truck to check it it has no power and is giving an map sensor code. there is no map sensor on this truck. He took the truck and got the engine built by another guy and the problems start. It starts up and runs fine just has no power at all. Also it has about 8psi of oil pressure when hot. do i need to check compression. any help would be great.
Sorry to hear that but it don t sound good.
does it knock? smoke? oil still brown?
There is a MAP sensor. Called a boost pressure sensor. When mine went out I got a few MAP sensor codes, it threw the truck into defuel mode. The result was no power or acceleration, I could maintain speed.
does not knock or smoke. i will replace the boost sensor monday. what about the oil pressure
A bad MAP sensor (boost sensor) would definetly cause some problems like low power, the ECM reads how much boost there is and fuels accordingly
I dont think the engine was built to good. what do u fellas think about the 8 psi oil pressure?
Banned
that really dont sound good what gauge are you useing? try a manual gauge if you havent allready:thumbsup
Discussion Starter #10
The gauge on the dash shows about 25psi. My otc scanner shows 8psi. i will check it manual though. Thanks
Discussion Starter #11
hooked a manual gauge up truck has 40psi cold at idle when it runs for about 20 minutes it drops to 8psi. Im going to pull the engine and see what he done wrong. what do u think?
Has he got the right oil in it? Did someone put some gasser oil in it like 0W20 or something?
1 - 12 of 12 Posts
