My first guess would be that your clock spring is starting to go bad. It controls the power to the horn, cruise control etc. I would disconnect the battery, take off the airbag and steering wheel, and look for broken tape in the clock spring. The airbag wire also may just have gotten corroded or loose.
I had this same problem with my truck when I first bought it. If it's not the clock spring I would check the passenger airbag on/off switch next. After that what I did was disconnected the harness off of the module and checked the harness going from the airbag to the module for continuity with an ohm meter. If you do this there are metal tabs that short out all the pins in the connector so the air bag doesn't accidentally go off from static so you would have to move those out of the way first. Also make sure the airbags is completely disconnected from the clock spring and you disconnect the battery and wait 10 min for the system to discharge. Hope this helps
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Cummins Diesel Forum
A forum community dedicated to all things Cummins Diesel! Originally founded for owners and enthusiasts of Cummins powered Dodge pickups, the Cummins Forum has expanded to include ALL Cummins Engine applications! Come join the discussion about reviews, drivetrain swaps, turbos, modifications, classifieds, builds, troubleshooting, maintenance, and more!
