99 24v mods in signature when I brake suddenly and actually come to a stop the gauge goes from 25-30 to nothin and check gauges light comes on for 5 seconds then back to normal only does it once in awhile... any ideas?
1st check the oil level. If thats good hook up a mechanical gauge and drive it, if the mechanical gauge holds steady but the electronic gauge in the dash goes crazy then you know its sensor or wiring related, if both gauges go crazy sounds like you need to drop the pan and check pick up tube and oil pump.
Oi level is good and im gunna get a mechanical gauge my supervisor said the same thing thanks for your input
probably your oil pressure sensor. had a similar problem and fixed it with the sensor.
