1 - 9 of 9 Posts
I know it's been said not to use the 99-02 HX35 with compounds but my HX is in great condition with the wastegate drilled out and everything...
"We do NOT recommend using this kit with 99-02 trucks having the wastegate mounted directly to the compressor cover as they cannot easily be "clocked" to the needed configuration. (crazycarl)"
Has anyone sucessfully used this HX35 with a set of compounds?
2007 Dodge Ram 2500 Mega-Cab Cummins
I have heard a lot of compounds that use the HX35 and put an S475, S472 or HT3B underneath it. They are supposed to be a great set of budget compounds and I believe that there are a lot of places that sell kits to bolt them right up. They have also been said to have great street driving manors.
· Mule Barn Proprietor
it works just fine if you use any common sense with the clocking. Wastegate mounting sucks but a simple flat plate extension bracket solves the mounting issue.
Thanks for the pics! I haven't looked at it too hard yet but when I get home from sea in a few weeks I'll be driving into the project... I think I'll attempt what you did there first and if not just a spring waste gate should do the job.
There are no mounting points on the housing to mount traditional spring gates. You will have to fab a bracket off the turbo mounting bolts.
Also, spring gates only open off of drive pressure, which works fine but isnt always ideal for every situation. I found the tuning better using a j hook of sorts to hold the puck closed against drive pressure, but using the stock diaphram acuator to over come that spring pressure . It can be done many ways.
1 - 9 of 9 Posts
