1 - 4 of 4 Posts
Hopefully I'm in the right place... So last week I noticed that I was loosing fuel pressure while driving home from work. By the time i got back my fuel pressure would never go above 10 psi and would drop to zero with any throttle. Its had a Walbro GSL-392 lift pump on for 50k miles and i assumed that it had crapped out. I replaced it with the same/new pump yesterday. While driving home from work today it did the same thing, never getting above 10 psi and dropping to zero with hany throttle.
Any thoughts or suggestions about what to try next would be much appreciated.
Brad
You dont have a signature. Do you have a Ppumped conversion truck? a standard VP44 pump needs 28psi idle and nothing under 10 WOT.
the Ppump is another story..Nothing under 55PSI WOT (that is what I got told by a guy who has a diesel shop and makes sled pullers as well as big tractor pulls
Your best bet is the 98.5-02 Powertrain forums.
Also what fuel pressure gauge kit u have?
There should be a course filter/strainer before the pump, check to see if that's clogged. Also check to see if there are any leaks before OR after the pump.
fule problums
fule
Hi I have a 2000 ram2500 24v and I'm not geting fule theirs a leak on top of the tank I thank my lift pump is not sinding fule my reader sed fule valve was stuck has aney one had this happen to their truck ?
1 - 4 of 4 Posts
