1 - 20 of 59 Posts
URGENT, READ MY LAST POST ON PAGE 4!!
I need some opinions here. First off is the budget. Im limiting myself to about 20k. If I buy a truck for 18k then I have 2k for goodies. Get it? My question is, what would you guys do? Find a 98.5-02 24v for cheaper and put more goodies on it or max my budget and find an 03 or an 04 which already comes with a little more power? Or is this a matter of personal preference?
Personal preference has alot to do with it. The next thing is, do you want the VP44 or the CP3.
i know the vp44 is pretty quirky, but i dont know enough about them to give you an answer
Man, you should've been on here asking that about a week ago..we could've pointed you towards Calebs truck he was selling (2005) for around that price. Looked like a wicked truck
Kinda depends on if you want a reg cab or a quad cab.... I love the '03+ quad cab. It's bigger than a extended cab, but not as big and a full crew cab. And sure beat the hell outa backwards opening doors! Just my .02!!
I'd go with the CR myself. Oh wait, I did!!! I was in the same crisis. I went with the CR mostly cause the cab.
I would much rather have a VP than the third gen injectors. The VP is much cheaper to fix. I would rather have a 03 or newer truck to drive because they handle better and more cab room.
thanks for the input. it sounds a lot like personal preference, i know they are both good trucks. i do like having the quad cab a lot though.
:welcome:
Given diesel prices today you can now actually find Common Rails for well under 20,000 if you look hard enough. Now one thing that I think you need a heads up on with the 98.5-02 and 03-04.5 trucks is they both have HORRIBLE lift pumps, the biggest difference is if the LP craps out on your 03-04.5 the truck shuts down and other then some minor aggravation you are ok. If the LP fails on your VP44 truck the fuel lubed pump starves itself and dies.
Like Brian said it really does come down to personal preference for a lot of it. The VP44 trucks seem to get a little better fuel economy cause they usually have higher gears available. The VP44 trucks also sound outstanding that said I love my common rail. I would say look around and see what prices are looking like around your area and best of luck!
One thing to consider that applies to both types of trucks, the manual transmission will get a little better fuel mileage if that is important to you.
Discussion Starter · #11 ·
yes a manual is a must for me, and another thing........if i get a NON H.O. will my upgrades bring me to the same power level as an H.O.?? what are the differences between the two (electronics, heads, fuel, etc.????)
It has been my experiance that the auto tranny trucks get the best mileage. The auto has the highest gear ratio (.069: 1) available in any Dodge Cummins application. That translates into less rpm. The differance is minimal though.
If you are considering a VP truck, beware the 53 block trucks. They are a weak casting and can crack.
Also, when you start modding a VP HO compared to a VP SO, the SO will make more power than a HO.
Discussion Starter · #14 ·
i wouldn't mind an auto, but for my application and preference im going manual. how do i know if a truck is an SO?
1 - 20 of 59 Posts
