1 - 1 of 1 Posts
got a 98 12v i cant get boost truck hag sat for a while wastegate was stuck swapped out to a known goot turbo adjusted to 35 psi. i found my lift pump was bad changed that now getting 20 psi at 2200rpm that is as high as it will rev underload with no boosted removed fuel plate just out of curiousity no change little more smoke im still thinking fuel problem but truck only has 76000 miles injection pumps arent cheap and fuel filter is new any ideas?
1 - 1 of 1 Posts
