1 - 20 of 35 Posts
Passenger slave leaked a bunch of fluid soaking the inside of the drum before it left a small puddle on the ground one morning. Popped the new one in, and started ordering parts to fix everything broken. This project took Me 8 whole days and probably around the clock once.
I ran into 5 problems. First the two of the lower sliding points on the backing plate for the shoes needed to be weld filled and ground smooth. The Passenger side e brake cable end ball would fit through the parking brake return spring(needed to file it down so it was round instead of oval). I welded the edge of the new brake shoes where it rides on the backing plate because two of them were flush with the friction material. The Forman adjuster didn’t have the slot for the drivers side cable to sit in so I cut a slot a little narrower then the original one.
The parking brake return spring wraps around, and clips into the parking brake arm, but the one I might have bent a bit removing wouldn’t stay clipped, so I took some bailing wire wrapped it through the hoop under the arm around the return spring, back under the arm, and twisted the bailing wire together.I did that for both sides just for assurance.
Font Gas Auto part Metal Coil spring
Automotive tire Tire Tread Motor vehicle Automotive exterior
Tire Automotive tire Motor vehicle Locking hubs Tread
Wheel Tire Automotive tire Motor vehicle Tread
Wheel Tire Automotive tire Tread Synthetic rubber
Font Art Eyelash Drawing Fashion accessory
Wood Font Metal Bumper Automotive exterior
Plant Wood Building Beam Shade
Tire Motor vehicle Automotive tire Wheel Tread
Tire Wheel Automotive tire Tread Motor vehicle
Is that the Dana 70 or 80?
Dana 80s can be upgraded to Chevy 1 ton wheel slave cylinders for improved braking performance.
Not sure if this will work on the 70s through.
It's my understanding that all 3500s had d80s, and only 5-speed 2500s had d80s, while 2500 autos had d70s.
Some reading and feedback here:
RAYBESTOS WC37337
Nice work!!
I have done everything i can do with the 94s rear brakes .
They only work OK.
Just dont seem to get enough pressure / juice .
I blame the olden anti lock alum block , or the compression coupling ( not my doing ) mid way to the brakes.
REAL CLOSE to re routing the rear brake line direct , via an aftermarket adjustable proportioning valve and a new hard line all the way back . I know one doesnt want tooo much rear stoppie , but id like to have enough to get the drums nice n warm , which rarely happens .
One detail which has stopped me from just jumping in ,, the lil hard line on the master clnd is bigger ( unknown if it bubble or double flared ) than the line that goes to the rear . Hopefully thats not a deal breaker .
IF anyone has done this , please share details .
thank you
Great and through job on the brakes.
Unrelated question, is the lower bracket for your air bag mounts upside down? Like shouldn't the flat side of the red circled brackets below be touching the springs and not the raised edges?
Automotive lighting Automotive tire Vehicle brake Wheel Alloy wheel
Reactions: jason867
MY truck came with the p
Nice work!!
They only work OK.
thank you
Motor vehicle Automotive fuel system Gas Auto part Automotive exterior
Automotive fuel system Motor vehicle Automotive tire Gas Auto part
Hood Automotive tire Automotive fuel system Automotive design Car
White Automotive tire Motor vehicle Automotive fuel system Rim
Dana 80. My brakes are excellent now. I would probably have to recalibrate the proportioning valve to use those cylinders eh? Also the Chevy might have bigger shoes and thicker drums. You could wreck the shoes, and warp the drums with the extra pressure maybe? Like compounding your brakes on a Semi truck.
RAYBESTOS WC37337
Nah, the Chevy rear brake cylinders are a way common thing / upgrade for the second gen dodge guys. I've had them on the back of my truck for years now, as have many others, without issue.
The mounts are correct.
Edit; I looked at the top, not the bottom. My mounts have U-bolts that go under the leaf so you might be correct.
Discussion Starter · #12 ·
Cummins12valve86.
IF those pictures were for me , looks like you still have the prop Valve and the anti lock all in the OEM config ?
There are no wheel speed sensors. I don’t know what that stuff is but it works. I slammed on my brakes in gravel, and loose gravel on pavement. The slightest little chirp and I’m stopped immediately.
There is a wheel speed (well, actually ring gear speed to be exact) sensor mounted on the center of the differential that inputs in the rear wheel speed to the abs module.
Reactions: 24hrsparkey
It probably doesn't really matter either way. Looks like its been working as-is for awhile now and those brackets aren't really supporting any load, just keeping the lower airbag mount from sliding off the top of the leaf spring.
2016 2500 CCSB
Drum brakes are dumb. I know I know, they’re better, they’re still dumb. They’ll soon be a thing of the past. I’ve scoured my area for someone that will turn drums with no luck, and the Chinese shat that new drums are made of are shaped like an egg.
I recently picked up a D80 disc setup with LSD for 150 bucks. Needs a pinion seal, calipers, rotors, and e-brake equipment. I’m looking forward to getting rid of the drums.
Drums brakes are not going anywhere anytime soon at least. Heck there are brand new, high end luxury, electric cars coming off the showroom floor with drum rear brakes (the Audi Q4 e-tron is one).
In fact the lack of brake drag that drums have compared to disc brakes is making them look good again in the eyes of those looking for fuel mileage and EV range. Here are few quick google search articles that talk about it a little, kinda interesting if you're into that kinda stuff.
Reactions: CHarrison9612v
2016 2500 CCSB
In fact the lack of brake drag that drums have compared to disc brakes in making them look good again in the eyes of those looking for fuel mileage and EV range. Here are few quick google search articles that talk about it a little, kinda interesting if you're into that kinda stuff.
Thanks, especially for giving me an example. I’m intrigued enough to see if there are any differences old vs new)
maybe they’ll make a comeback like all the other terrible things from the past. If the tree huggin hippies want them in their ev’s….be my guest.
For me, I’ll stick to disc’s.
Discussion Starter · #19 · (Edited)
I’ll keep My drums. Every semi truck I’ve ever driven has them, and for good reason. They prevent dirt, and water from constantly bombarding the brakes. I’ve seen so many problems with rear discs it’s not even funny. When it comes to EV’s I’ll never get rid of My 12 valve, but the 2007 Honda CRV will go to some poor ******* if I can make enough money, Ill get a RAV4 Prime.
This is what gives Me ultimate power and control through the week plus sugar free rockstar, decaf Swiss coffee, and Organic green tea from southern Japan. I call it the sausage, and egg Mcgrease! Olive oil in the pan to thaw and cook the sausages covered on low, and a jalapeño mayo from Costco. Made with good old cancerous canola oil.
Food Tableware Ingredient Cuisine Dish
Food Tableware Ingredient Kitchen utensil Dishware
Food Ingredient Cake Cuisine Dish
For My next dose of healing My back pain other then stretching, and walking is to eat protein and vegetables. That’s about 2 weeks worth of coffee creamer. 😁
Ingredient Cuisine Dish Gas Automotive lighting
Liquid Bottle Shelf Solution Fluid
Food Ingredient Recipe Automotive lighting Cuisine
2016 2500 CCSB
I’ll keep My drums. Every semi truck I’ve ever driven has them, and for good reason. They prevent dirt, and water from constantly bombarding the brakes. I’ve seen so many problems with rear discs it’s not even funny. When it comes to EV’s I’ll never get rid of My 12 valve, but the 2007 Honda CRV will go to some poor *** if I can make enough money, Ill get a RAV4 Prime.
Drums on a semi are slightly different than our hydraulic drums.
1 - 20 of 35 Posts
