My 96 reg cab 4x4 nv4500 has always started like a champ. I mean it fired up fast every time. Lately that has changed and I have been working to fix this issue for a while now. The cold snap we are experiencing is exacerbating the symptoms to the extent that I am worried it will not start one of these mornings. Thus far, it has not failed to start. Keep in mind this issue is not ambient temperature related. It began when it was still 70*F outside a few weeks ago. The cold has obviously made it worse but is not the cause.
SYMPTOMS:
*Slow to crank. The rrrr...rrr..rrrr.. that we all dread.
*Battery gauge on dash heads south when the key is turned on. It will be down in the range of 8 or 9 before the 'wait to start' indicator turns off.
My first thought was dirty connections. So I removed battery connections and cleaned all the terminals and connectors. No improvement. At that point I crawled under the truck to check connections on the starter to see if one was loose and not making solid contact. They were dirty but tight so I cleaned them up as well. From here I decided to check the alternator output to see if it was keeping the batteries charged. I had 14.1-14.2 on both batteries while the truck was running. Hmm. Ok, let's load test the batteries to see if one is bad. Nope, they load tested fine. . Now what? Ok, did some reading. I thought maybe the starter needed freshened up so I ordered LarryB's upgraded contact and plunger set for the starter. Pulled the starter and installed new parts with great anticipation but it was to no avail. I considered that the grid heater may have taken a dump on me so I disconnected the wires on top of the intake elbow which power the grid heater. That made zero difference thus eliminating that as a problem. For the hell of it, I put two brand new interstate 810 cca group 27 black tops in the truck. Again, no change.
I am down to thinking there is either a monster somewhere that I don't understand or that I need to replace my crossing positive cable between batteries.
Thoughts before I waste more time and money?
Thanks,
Michael
SYMPTOMS:
Thanks,
Michael
