1 - 9 of 9 Posts
Hello to all, did the 96 Ram 2500 have a shift motor for the transfer case?. was that an option?.
want to get rid of shift knob on floor.
The 10th Man
no shift motor, that wasn't an option until 03 when they went to the 271 t-case
Yeah and a newer style transfer case wont fit between the frame rails
The 10th Man
you sure on that one hoss?
It’s close but they fit. I’ve heard some guys say they’ve had to beat on the frame rail but mine fit with a 1/4” to spare.
I seen a guy try to put one in a 98 and it would not fit. Unless he beat the frame rail in
Hookit can you post pics of this T case and frame rail?. and all mods made to make it work?. Thanks.
I’m not sure if my setup will help any. My 271 is attached to a zf6. Although center line remains the same, driveline and crossmember etc. won’t be close to what you are trying to accomplish. I can take a pic if you want.
Discussion Starter #9
maybe I could just weld on a handle at the transfer case. that would have me to crawl under. or a custom shift lever under the seat.
1 - 9 of 9 Posts
