1 - 14 of 14 Posts
Ok I just did a trans swap from auto to a nv5600. The engine has stock injectors with a zero plate and a hx40 hybrid. The truck pulls like a tank I'm just trying to tune it some to get the egts down some and make it more efficient with power. Any ideas
X2 on the AFC tuning. Also, check for boost leaks because that turbo should be pretty efficient with stock injectors. Any other pump work done?
Try turning the starwheel to tighten the afc up, check for boost leaks and bump the timing up a bit.
I thought it was all the way loose. Try a stiffer spring if it is all the way toward the engine.
1 - 14 of 14 Posts
