I have a problem with my 95 dodge lift pump. The truck is running fine but it is dripping diesel fuel from the lift pump. When the engine is running and you barely push the primer it will put out a steady stream of diesel from the left side of the pump. The lift pump is less than 30k miles old.
1. Is there a way to fix the leaking lift pump?
2. How and where are the bolts to remove the fuel filter.
thanks,
Mike
thanks,
Mike
