1 - 4 of 4 Posts
The problem I am having is with the CAD i replaced the vacume actuator with a posi lok and it still keeps popping out I know its adjusted right but when I pull the cable to engage it it will work for a bit then pop out then it strips out the cable and bends the pin that the fork goes on whats the problem? Is there a one piece axle that I can put in place of the CAD or what. Trying to keep the budget low so the hub coversion is out of the question.:thud:
Tech Specialist
would that kit create like a locker affect when the truck is in fwd? sorry i don't quiet under stand.
Tech Specialist
Only if you have a locker in the front diff. It replaces the axle shaft so both sets of shafts spin the same speed as the tires always. The front diff will turn the front driveshaft. The front diff will allow the axleshafts (and tires) to spin at there own pace.
1 - 4 of 4 Posts
