1 - 4 of 4 Posts
curious where you guys install the trans temp gauge and boost gauge. For the trans temp gauge i heard that you can use the stock location with an adapter, any one know what size thread that is?
AlGores worst nightmare
Sorry, yes sender
I see where the boost is put in but how about the trans temp sensor, don't really see how its done in the pic
The stock trans temp sensor is basically useless. If the trans gets hot enough to cause the warning light to come on it is damaged. If the trans is too cool the PCM won't let it shift into OD which is a PITA.
Pull the connector off the stock temp sensor and put a 1K resistor in it. That will satisfy the PCM that the transmission is warm enough to allow OD. Then put your aftermarket temp sensor where the stock one was. That puts the sensor in the hot cooler line which is where you want it. This won't work for '96 or later trucks (47RE transmission) because the cooler line is not the same as for your '94 with a 47RH transmission.
1 - 4 of 4 Posts
