The bulbs are back behind the cluster. If you search around for the tutorial on swapping LEDs into the cluster, you'll find how to get the cluster out. It's really straightforward.I tested the fuse and it showed the voltage to the fuse varied from a low of 8.0 volts to a high of 12.5 at top setting, so, swith appears to be sending voltage. Guess it is the bulbs... will try to figure out where they are.
