i know what your talkin bout i turned the truck off an tryed to hold it back but nothin happened im thinkin somethin is up with the plunger in the soleniod the guy i bought it from siad the pump was turned up but i dont know how much and the 2 wires arent hooked up i tryed to hokk them up an still nothin bout i preciate the help im new to the cummins scene and jus to let u kno my truck looks exactly like your blue and allCan you see where this is? Just below the throttle linkage. Just hook the cable to one of those holes. I used a short 1/4-20 bolt and nut and wrapped the cable around the bolt to keep it in place.
I just ran it as straight as i could into the truck, not hitting anything else in the engine compartment. It looks like this inside of the truck.
i dont mind the pull cable method but this mornin i couldnt get it to start so now im tryin to get it to crank it acts like a bad terminal connection but i cleaned them still nothin im thinkin maybe a relay somewhere but i dont know where they are on these dodges never owned 1 b4 i need to get a haynes manual!you could try and get a new plunger if you want it to work off of the key but it might not work like that very long unless you turn your pump back down.
$10 Magnetic Valve (Start/Stop Solenoid) for VW Diesel Injector Pumps. VW Diesel TDI
