what does that equal in timing on a 95 1550 engine? timing lift is at 7mm. is that 19 degrees? everything else on this motor is bonestock as far as I can tell. should I back it off to 16.5, and if I do, and I gonna lose fuel mileage, since most gain when going up?
never could get the timing pin to go in, so I had to take it off the motor and find the spot with a finger, then put the pin back in. what a pain!
Tech Specialist
If your really worried about it you can back it down for comfort. But why mess with a good thing is all I'm saying.
