1 - 4 of 4 Posts
i have a stock 97 3500. it died while driving like the key was shut off. i checked the shut off syl pull and seemed to be correct. i cracked the inlet line to the pump, have fuel comming out(dont know the pressure) no fuel comming out the return or the injector lines. am i going to have to take the pump off and in to someone? if anybody has ny insite it would be greatly appreciated.
truck cranks but doesnt start. i have fuel comming out the incomming banjo fitting of the pump. i hane no fuel comming out the return off the pump, or out the injector lines like my rack isnt moving
You wrote that you checked the shut-off solenoid pull and it seemed to be correct but does it stay pulled with the ignition on? Turn on the ignition; pull the solenoid plunger up by hand. Does it stay up? If not, hold it up and have someone crank the truck. If it runs you know where to start.
Read the article Dual K20s mentioned.
1 - 4 of 4 Posts
