Has any one swapped from a 93 dodge aftercooler to a 7.3 power stroke aftercooler? What year was it from? Was it a lot of fabricating? My stock dodge cooler is shot and new one is 595.00:shock:
sequential or compound?Continuing what Bobby said . . . The proper application of a true intercooler would be to install it between the primary and secondary turbos of our so called Twins set-up (technically twins is wrong, it's a sequential setup).
Sequential is correct for that we call twins. One feeding another in sequence.sequential or compound?
If you have a non I/C truck, any intercooler is better than the one you have.if you have a non-ic would it be worth it just to go straight to a 7.3 intercooler?
Not sure how it will fit in your older Ford. It is thicker, wider, and taller than the stock 93 cooler. I turned the 2001 cooler I put into my truck upside down to make the inlet and outlet tubes line up closer to what the 93 was like and then had to cut out at the outer sides of the holes in the front sheetmetal about 3/4" wider. The feed tubes from the turbo and to the engine are larger as well and I replaced those with the larger sizes. I think the 93 was 2.5" and the ford 3".Back to the question, what year ford aftercooler (intercooler) is used?
CAC covers all of them... then you get into intercooler, aftercooler, ect... :thumbsup:'99-'03 powerJOKE's had the full aluminum intercoolers and are the ones you're looking for.
the technical term for an intercooler is a charge air cooler (CAC):bdh:
