1 - 10 of 10 Posts
any one running one, and is it all really 6inch under the truck, or is it just a tail pipe
my brother outlaw has 6" from his turbo back on his powderjoke and it sounds sick (no tip straight exuast) so yes it is under the truck not just tailpiped
I would not do a 6inch....unless you just want to say you have it
why would i loss power with a 6 inch exhaust, wouldnt it be similar to running 6 inch stacks
how would it loose power?
Well have I heard having an exhaust too big can cause eddies, or swirling masses of a fluid, in the exhaust which do not help the cause. I don't know it a 6" will cause it or not. Also most stack kits are only 6" on the stacks themselves, the extension pipe and down pipe are usually 4" or 5"
correct rufus.
imagine a hose that's 4" and water running through it at 10psi at 50 mph, now increase the size to 6" but keep the psi the same, the water would move slower b/c it has more room to disperse it's energy, thus slowing it down and making it less effective.
understand.
there is a happy medium when it comes to power and exhaust size. now while i don't agree w/ the over 500hp go to 5" and anything under stay w/ 4", i know from personal experience that the 6" loses power on an under rated truck.
i mean look at some of the people out there running 800-1000hp they only have a 5".
Tech Specialist
These trucks contrary to popular belief like a little back pressure. I had a straight through muffler on my 5" exhaust and put a hush power on and it helped spool up, throttle response, lowered cruising boost and egt, and you could hear the motor not working as hard. My buddy has a smarty, power puck, tst, sb66, stock intake, and stock exhaust on his 04. He straight piped it and actually lost spool up. So don't go with a 6".
1 - 10 of 10 Posts
