My 68RFE bit the dust at 230K - was trying to get unstuck in the snow, riding the brake to keep the wheels from spinning. Lost 1st gear. Pretty sure I broke the sprag. I can drive it around in reverse or 1 on the selector, but in D it goes about 10 feet, then throws code P0731 and acts like it goes into neutral
I run an XRT Pro on the mild setting. Stock tires and gears. I have not added the trans tuning to the XRT but will probably do so after the rebuild.
I've rebuilt transmissions before - so i'm going to order a rebuild kit of some kind and rebuild it myself with the ATSG book.
I was thinking about getting this kit:
https://www.dieselpowerproducts.com...-it-transmission-kits-075-18-67l-cummins.aspx
What do you guys think of the BD kit - in particular the included sprag? Separately it's priced at $295, and most other heavy duty sprags are ~ $600, is the BD a good sprag?
I haven't had any issues with the 68RFE thus far, so i'm seeing no reason to upgrade it much past stock.
