1 - 20 of 36 Posts
Wondering if it is possible to switch from a 68RE to the G56 Manual...seems like if I were to get a new auto tranny and torque converter..might just do a full trans system swap.
Anyone ever done this or thought about it?
its possible but may br cheaper to trade it for another.
considering this down the road as well.
The mechanics of it should be fairly straight forward - the electronics will be interesting to say the least. I would think the easiest approach would be to find a ECM from a manual truck or perhaps in the future someone will be able to do a custom flash for this type of swap.
I don't think the starscan will allow loading a manual flash on an auto ECM or the other way around, might be wrong though.
For reference check out the 68rfe to 48re story, it worked but seems to be stuck in torque management mode, probably has something to do with the TCM not seeing a transmission anymore.
Yea I think the flash can be switched talk to H&S, they can do amazing things. I am pretty sure they had to do that to figure out my problem.
Mr. Vehicle Destroyer
The best way to do it is to find someone wanting to go manual to auto and just swap everything. To do this you'd have to make sure gears and auxiliary equipment were the same. The Braking ECU would need to be swapped as well. Parts of the cab harness need to be changed to in order for your cruise control to still work.
It's easier to go from auto to stick then vice versa.
Discussion Starter #9
Hey Keven know anyone in portland area that I can talk to about this...and get some $$$$$ idea of what it would cost?
The only thing I am wondering if the ECM has to be changed..besides doing all the programming changes to the transmission system, if I changed it to a ECM with a manual set up. Wondering if the injectors would have to be reprogrammed with a star scanner.
:banghead:
CF Administration
:banghead:
if I was you I would get ahold of reb at browns diesel I think they are in north cali so not to far off, if you put a new ecm on any 6.7 you have to reprogram the the ecm with the injector numbers I have seen it first hand
Hey Tony, You could try talking with Rip at Source.
I've yet to talk with anyone that has actually done it though a lot of guys are considering it since a decent built auto doesn't look like it will be available anytime soon.
Discussion Starter #12
Yes that is my concern...figured a billeted 48RE is in the 7-8K region with a TC...wondering if I can get a manual fab swap. for less.
I would think so. The least expensive way would be to find someone that wants to swap.
so if i found a 6.7L with a g56 at a wrecking yard what would i need to do the swap? i know the trans and shifter and clutches but would i need the ecm?
I've done the swap from a Suncoast 68 to a G-56 with 3600 SB DD and the G let loose so it now has a NV5600 with a 3850. Yes it can be done i have done it the SMARTY works miracles when doing the swap talk to Wagner or call Fleece, they are the ones that done mine.
Subscribing, i'd love to do this swap too
Go with the NV if you plan on having some HP and TQ
what is an nv? and how much did the swap run?
an NV 5600 is what early 05's and previous trucks down to, i think 02 had. 01 or 02. It is a metal housing instead of an aluminum housing or case. I did a little trading with a guy, my suncoast 68 for a used manual, sb clutch, and install. Cheaper than a built auto i can tell ya that.
1 - 20 of 36 Posts
