1 - 20 of 174 Posts
Pulling the trigger on a hopeful 650 build. I am going for streetable performance and occasional towing. (horses, TT, Equipment). Here's a list of what's been bought and collected and work planned. Not all necessary of course, but adding mods is addictive! Also, fixing things on my to do list as I go.
-I went with PDD Ultimate Towing Compound Kit. K27 and s369. Added Kobra Kai intake horn, and Blankets, and wrapped hot pipes
-PDD Turbo Tuner
-215 Pump from PDD with 7mm DV's, 4kGsk, and 20* (adjustable Ofv)
- 5x14 VCO from PDD
- Push rods from PDD
-Resurfacing and oringing head, med port and polish
-Steed Speed manifold with blanket
-Conical 165# springs from PDD
-Top hat valve seals
-AFC Live
-Modded lift pump from PDD (changed to PDD predator pump)
-ARP 625 studs
-Fluidamper, pinned
-850hp Built 47RH from PDD with triple disk, 2nd lockup, Billet flexplate
-Fuel sump with 1/2 lines
-1/2 lines from lift pump to filter, Filter to Pump (2 line feed)
-banjo bolt replacement kit
-5" SS MSRP exhaust, straight with FTE resonator, 8" Prius Repellent Tip
-Mishimoto stock replacement trans cooler
-Mishimoto Rad
- Billet Timing cover, Tappet cover
-Fleece coolant bypass
-Scheid tappet vent box
-2 twin vented Valve Covers for 2-3 and 4-5
-New vac pump and steering pump and lines
-Redhead steering box
-ss brake lines, hard and soft (braided)
-New rad fan, plastic from Genos
-BD exhaust brake inline, (have on board air)
-Kennedy Dual boost gauge (already have full gauge set)
-Drive pressure gauge
-24v Oil Pump
-Oem water pump
-Silicone Rad hoses
-380A alternator from Quality Power with external reg
-Mean Green starter
-SS throttle linkage
-BD cool down timer
-BD intercooler
-BD double stack trans cooler
-CBR oil cooler
-Engine oil pre-luber system
-Dual cat 2 micron fuel filters with Baldwin water separator and 100 mesh screen
I'm driving up from Los Angeles area to Power Driven Diesel in Utah as soon as they are ready to install the tranny. I'll have them install the coolant bypass at that time because the tranny will be out. They are going to get rid of the plastic cooler line clips as well.
When that is completed I'll pull the head off and get started!
I'll make periodic updates. Should be fun!
Discussion Starter · #2 ·
Added the BD intercooler to the list. Should be here in a few days. Replacing the condenser as well since it's messed up a little.
Looks like fun.
Do you tow?
Hope you document this build, it is difficult with so much to do.
Sounds like a nice build. I agree with the BD intercooler. Been running one for years and it frequently sees 85-90psi.
-I went with PDD Ultimate Towing Compound Kit. K27 and s300.
Stupid question : I'm assuming this is the k27/S369 compound setup?
thanks.
BJ
That's it. I need the faster spool for the occasional towing I do.
Reactions: no_smokn
Making some progress. Got the 215 maxed and balanced pump painted and the dual feed hooked up. Flows 550cc. Did the bushing mod on the throttle and replaced the ball and socket hardware. 7mm DV's
Reactions: benjamin8161
Turbo housings painted.
Oil cooler arrived and thinking of a bracket.
Engine mounts replaced.
Oil pre-luber installed
Discussion Starter · #9 ·
Installed Mean Green starter.
Built relay box.
Machined head for Top hat seals.
Machined off built in filter iron inside intake manifold.
Discussion Starter · #10 ·
Head O-ringed.
Valves lapped in.
165# springs with tool steel retainers and collets installed.
5x14 vco injectors installed.
Head machined.
Discussion Starter · #11 ·
Dual breathers.
Mirror intake.
Pump Installed. 20* timing.
Discussion Starter · #12 ·
Updated oil pump.
Drilled and installed Cam retainer.
Pinned Dampner.
Dampner installed.
Reactions: MOJO
Discussion Starter · #13 ·
Billet Tappet cover.
Billet Freeze plugs.
Billet front cover.
Machined Rockers.
Installed Head. ARP 625
Discussion Starter · #14 ·
Odyssey 2150 batteries installed
Stage 2 push rods
Discussion Starter · #15 ·
Steed speed
MLS gaskets
Discussion Starter · #16 ·
Traction Bars installed.
Down pipe Wrapped.
Various pieces painted.
Discussion Starter · #17 ·
All wires Loomed with easy loom.
All new battery cables
380 amp alternator.
Borgeson steering pump.
Red Head box.
New vac pump.
AFC Live installed.
Turbo Tuner tubing laid out.
Discussion Starter · #18 ·
Got the steering pump oil thermostat plumbed in with a filter. Cooler tubes will be in front of factory trans cooler.
Also, here's a snap of the steering shaft.
And a snap of the pre-luber solenoid and plumbing.
Discussion Starter · #19 ·
Wiring for the on board air. Going with 80 amp circuits per compressor this time. These AMP compressors by Pacbrake are just awesome. They even come with unloaders. 3/4 hp each and 3.4 cfm each.
Discussion Starter · #20 ·
Pic of the Odyssey 2150 specs. I went with group 31 and they fit just fine with a heat gun and a little trimming. Custom hold down brackets.
Reactions: MOJO
1 - 20 of 174 Posts
