1 - 10 of 10 Posts
I put a 6" superlift on my truck and I'm getting a driveshaft related noise (I think) :confused013: My question is, am I the only one with this noise and this much lift?
Did you install the drop bracket for the trans? Do you have a 2 piece rear drive line? If so, did you shim the carrier bearing down. You wont need a new front shaft but maybe a index ring from Spirson.
· Silver Bullet
Well he has a mega cab so its a two piece rear drive line so he should of got a shim for it. And make sure you put the rear blocks in right since there angeld for the rear drive line. Just turn your axle up and you should be fine.
i think i have the same problem, but not sure if its coming from the front or the back or both. im leaning towards both, sometimes it sounds like its right under me then others towards the back, ive been meaning to take it to where i got the lift to see what they say but havent had the time. ive had a couple people tell me they think its the U joints but idk
I have a one piece rear driveshaft. And I'm trying to get 4wheelparts to tell me if there was a transmisssion drop bracket installed. I compared it to the one on my 4500, and they look pretty much the same?!? I'll wait for a call from them to confirm.
Oden,
I have a 6" lift and was getting a noise/vibration at hwy speed. The rubber boot that covers the splines was tight and not allowing the drive shaft to extend freeley.
I had the local drive shaft extend the shaft 1 1/2 inches, that did the trick.
1 - 10 of 10 Posts
