1 - 4 of 4 Posts
ok i have a 6 blade (60mm i think) hx40.......
how much of a upgrade would it be on my 97? 60hp injectors and 0 plate? it gets toasty pullin a trailer
98.5'-2002 HX35's are 7blade compressor 54mm x 78mm, turbine 58mm, 12cm^2 dual volute wastegated housing.
94-98 HX35's are 8blade compressor 54mm, turbine 58mm, 12cm^2 dual volute wastegated housing.
hx40's for 6 blade are compressor 60mm, turbine 65mm, 12cm wastegated housing.
The 40 would be a nice upgrade for you. You may have bigger than a 12cm on the hx40 depending on what it came off or if it has been changed.
if you don't wanna upgrade i'll take it off your hands. i've been wanting an hx40
it came off a 8.3, i think it has a 14cm exhaust housing
1 - 4 of 4 Posts
