1 - 4 of 4 Posts
just started to have a problem with my truck when i'm passing some one or accelerating up a hill where its cutting off my fuel it seems like. even like when i'm at half throttle level 3 on my chip and egts seem higher then normal when accelerating. then i get fuel delivery error code and some times the fuel rail pressure too low also fuel rail pressure too high relief valve activated
also 2x i had my trucks egts jump and have to shut it off to make it stop. i was even going down a hill getting 1100 degrees at 2 psi boost like not even touching the throttle and when i stopped it would idle round 600 degrees
if you got any ideas it would be appreciated
Formerly Az2500Cummins
Which "chip" do you have? Fill out your Sig so we can help you.
it a Edge Juice w/attitude
there i think i did my signature
1 - 4 of 4 Posts
