1 - 13 of 13 Posts
hey any one thought about or know any logistics on swapping a turbo from a 6.7 onto a 2nd gen.
I don't know about the mounting, but if you could get it mounted, i know you would have to have some sort of controller for the variable geometry vanes.
Mostly i just love their crazy whine at idle, and i think if you made it work right, it would probably make your truck a little bit more efficient... and i would imagine that it would be able to cool a bit more power than an hx-35.
Any thoughts?
SC Chapter President
I've thought about this as well, not sure how you'd control the variable vanes though, but those type of turbos are very awesome, it's kind of like having a set of twins. I would like to figure out if it's possible to do it.
Discussion Starter #5 (Edited)
they might be different but that doesn't mean that you couldn't make an adapter or modify exhaust manifold.
the other major advantage that i forgot to mention above is the built in exhaust brake... that would be awesome
You can make anything fit, it usually just takes a bigger hammer:rof
still wouldnt be worth it, last time i replaced a 6.7 turbo the retail price on it was about 2900$... might aswell buy an aftermarket one and install an exhaust brake...
Discussion Starter #8
thats assuming that you can't pick one up for cheep, when someone upgrades theirs... eventully they will become more available and cheeper
Tech Specialist
There are a few on Ebay that seem to be reasonably priced. And when you take into consideration what it is, Its not that unreasoably priced. I'd compare it to a ball bearing turbo for spool and flow and with its e-brake capabilities. A Garrett or Turbonetics turbo costs $2000 and an E-brake another $1000. Thats the same price as a new one.
eBay Motors: 2007-08 DODGE RAM CUMMINS 6.7L VGT HOLSET TURBO CHARGER (item 190223055651 end time May-24-08 09:05:34 PDT)
I would consider swaping one or even a HE351 off of a 04.5-07 for a stock to 425hp truck
I wouldn't suggest the swap unless you have some way of making a PWM signal. That is how the Vanes open and close. It isn't just an on off switch. I don't even think a variable resistor will work. I may be wrong. I am a little more screwed than others as I have 5" exhaust and can't find a manufacturer that makes one for 5". Hell the engine is fully capable of one.
Pacbrake makes 5"???
my 97 has twins and ht3b is 5" so it is 5 all the way back.
Mr. Vehicle Destroyer
It isn't even a PWM signal it is a full blown CAN message. There is a can message to control a stepper motor and gear drive to shuttle the sleeve...not that I was looking to putting one on my truck or anything :w: I picked one up on ebay for 175 bucks.
1 - 13 of 13 Posts
