1 - 11 of 11 Posts
Does anyone have any info on put a smoke switch set up on a 6.7 i was just curious if any one has tried it and if it worked as planned.
And also does name which wire is which color on the map/mat sensor harness.
US Army June 78-June 06
I think the closest anyone has gotten to a smoke switch would be the Fleece Boost controller. Because you can adjust the vanes in your turbo you can make it smoke from what I have read.
been watching for it but none has figured it out yet other than like sad the boost foolers
Smoke switches concern me if you do not know what you are doing. I have had more than enough calls where guys have added a home made switch thats has fried their MAP sensor. The last guy shorted the MAP and toasted the Edge :banghead:
James
RSD
can you turn the boost down with the Zilla fooler like you can with the fleece
I have the fleece controler on mine. The fleece all the way down and my mp-8 all the way up and my power pup = lots of smoke.
CF Administration
I think i was the closest with the map sensor trick search you will find alot of my threads on how to do it
1 - 11 of 11 Posts
