I am throwing this back at the 6.7 crowd. I installed my new FASS 95/150-1007 today and had a few problems( it wont run) :thud:The instructions are a little confusing so I went to there web sight, not much better. The picture of the injector pump is not quite right, the instructions for connecting the main power wires were different than the instructions online. The instructions I have in hand say to connect the green wire to the battery ground, the red wire to the lighter fuse? I followed the suggestions from the replies on my last post and connected the red wire to the POS battery post. The pump still has no life. Does this sound right "At the fuel tank there is an electrical connector connecting to the to of the fuel tank. Disconnect this connector; gently pull this wire harness and connector bellow the frame rail. Simply cut the black outside wire, this is the wire at one end of the harness going into the connector. FOR AVAILABILITY OF THE STOCK FUEL PUMP AT A LATER DATE CUT THIS GROUND WIRE AWAY FROM THE CONNECTOR, THIS WILL ALLOW FOR EASIER CONNECTON!" So tomorrow I am going to reconnect the outside black wire even though the pump did not come on at the auto hobby shop with it uncut. The worst part of my day was when I had to call one of my friends to tow me home with his FORD!!!!! :butt:ANY SUGGESTION WILL BE GREATLY APPRECIATED.
