I just bought an edge insight does anyone have any pics or an explantion of where I tap a egt thermocoupler in I am new to all this just dont want to drill it in the wrong spot.:confused013: Also how do you get the wire from under hood and into cab to connect to harness?:confused013: Please help
I don't have a pict, but there are a lot out there (use the search button). Just drill in the collector area right above the turbo. As for getting it into the cab, there is a pretty large grommet right int he floor board on the drives side (not sure if that is because I have a manual or not)
Good luck:thumbsup:
Braaap, Braaap, BOOM!!!
Ya just drill and tap into the collector on the manifold. We just put in an Insight wiring harness and EGT probe on my friends 07 Cummins who has a Dash Hawk a few weeks ago. He already had a hole drilled in his firewall through the blank clutch hole from past installations. Let us know when you got it in.
:headbang: I did it :headbang:thanks so much guys could not of done it without your help and pictures I really appreciate it. I just love this forum I have now done a bypass and thermocoupler and both went really smooth with no probs all b/c of this awsome forum and the helpful guys:thumbsup::party018::yourock:
