1 - 1 of 1 Posts
For those who find this a pain in the butt because there is no pic under the hood, here you go, just click and save, I'm gong to print one and place it in my glove box or make it a sticker for under my hood
Replaced my water pump this morning and ran into the same problem, after 2 attempts to re-install the belt i did a google search and found this, probably should of done that first off
Also by the way when replaceing the water pump or even just the belt, it is 100% quicker to pull the tensioner, its just 1 13mm bolt so that you can loop the new belt around it.
I would not want to be on the side of the road trying this by the way, it takes more time to get the belt back on than to change the pump
rick
1 - 1 of 1 Posts
