Ok so if I go ahead and get the compounds and tow about 15k pounds what setting should I leave my smarty at and I guess I better do head studs?
What do you mean "if your truck has minimal muffling and no cat plan on changing that when you start towing!"
Just set the Smarty at low HP levels and work your way up. Your EGT gauge and water temp gauge will tell you what your limits are when towing.
Once you start playing with the Smarty, you will have to try numerous things to get a feel for it and the changes in how the engine runs.
There are lots of guys that crank up the Smarty to 11 but usually they are not towing or they have a spare engine ready to go.
I recommend to do headstuds, injectors and valvesprings all at the same time if possible.
The top of the engine has to come apart to do all 3. Installing headstuds without the injectors in place is easier and safer.
One shot and it's all done.
Once you start towing, a straight piped or minimally muffled CR Cummins will drone like crazy when towing.
Some guys don't mind this but it's not for me or my family when towing the RV.
My twins did not quiet down the truck one bit, contrary to popular belief.
I went from 1 small straight thru muffler and no cat, to 2 larger straight thru mufflers and re-installed the cat.
Exhaust is free-flowing, legal and quiet when towing up a mountain with the trailer.
In my experience the cat made zero difference to power, EGT's and fuel mileage.
Of course an exhaust brake is worth every penny when towing. Hey, it's only money!
With twins, a remote mounted ex brake works totally fine.
If you look at my signature, you can see that my truck is also an NV5600 and set up for towing.
I don't recommend the BD short shift kit on your NV5600 and I don't recommend an aftermarket intercooler.
If your 2005 has a plastic intercooler, start shopping for a good OEM metal replacement.
