for better fuel mileage what combination is better 5 or 6 speed in correlation with rear end 4 10 or 3 55s or 373s just wondering. thanks guys
Not completely true... the first gears are very similar in both transmissions, the drives (1:1) are the same, and the overdrives are very close to the same. It's the gears in the middle that are switched up.The only difference would be towing. The six speed has a lower 1st gear. Both the 5 speed and the six speed overdrive ratio are very close to the same. IMO the best rear axle ratio would be 3.54's with the right height tire.
the 1st gears are almost exactly the same, and the overdrive gears are exactly the same (.73) just with the 6 speed there is 4 gears inbetween and 3 with the 5 speedThe only difference would be towing. The six speed has a lower 1st gear. Both the 5 speed and the six speed overdrive ratio are very close to the same. IMO the best rear axle ratio would be 3.54's with the right height tire.
this is a 2wd but it can be done on a 4wd allsoHow did you fit a G56? Everything I read said that they wouldn't fit in a 2nd gen body. Pictures?
Did you just call a five speed a waste of time... wait yes you did. I tow, and my boss tows bigger, (city driving... ha been there but not often) we don't like the price of rebuilding a six speed and both trucks have all the power in the world to tug anything that wont just flat out crush the frame hooked to the back.The 5 speed is a waist of time, if your a city driver and don't tow you wont have a problem. If you do tow then the 6 speed is the only way to go,.do your self a favor and go 6 speed.
well I didnt say trash I said waist of time if your towing you can defend the nv4500 but been their and done that,but rpm drop 3-4 sucked I don't care how much power it made pull a 35ft goose up a ramp to the freeway and unless your shifting at 3k good luck.you may be right now that I think about it trash is the right word,Did you just call a five speed a waste of time... wait yes you did. I tow, and my boss tows bigger, (city driving... ha been there but not often) we don't like the price of rebuilding a six speed and both trucks have all the power in the world to tug anything that wont just flat out crush the frame hooked to the back.
That's all well and good that you put a 6spd in your truck and are suberbly happy with it, but I wouldn't go calling a 5sp trash, if you drive it like a driver then just hook up and go regardless of an EXTRA gear or noteelout.
all that was said about 1st and final gear ratios is correct, minute if any difference.... I'm in the market for a gear vendors (more shifting that will actually help fuel economy) :$:
well considering my buddy is a farmer and tows cherries with a 96 5-speed, i'm pretty sure the 5-speed is not a waste of time or trash. gonna have to agree with burgandy on that one buddy.well I didnt say trash I said waist of time if your towing you can defend the nv4500 but been their and done that,but rpm drop 3-4 sucked I don't care how much power it made pull a 35ft goose up a ramp to the freeway and unless your shifting at 3k good luck.you may be right now that I think about it trash is the right word,
