1 - 4 of 4 Posts
Basically, I'm trying to find out if i am missing a foam sound deadening piece on my transmisssion hump shifter hole on the 5 spd 1995. All I have is a rubber water tight gasket and then the leather looking cover. No foam element at all, so lots of tranny noise and engine noise coming through. Is there a foam insert for these things?
Also, how loud are the 5 spd when idling with the clutch out? I have a GM truck with an NV4500 and it's not that loud. An y ideas. It seems strong and no issues mech. just had a new Southbend clutch in.
Any info appreciated,
Thanks
Art
Tech Specialist
Mines the same way with the two boots only.
You could add insallation if you wanted but the cummins is just a noisy engine in general, especially compared to any GM
It turned out that both covers were not sealed correctly, allowing more noise through.
I think I'll get some jute for sound deadening...
Thanks Gents.
Art
1 - 4 of 4 Posts
