1 - 13 of 13 Posts
So, I replaced my right front hub assembly yesterday and decided to take pictures during the process. I know there are other threads on here for replacing the front hub assembly, but I am trying to make one as detailed and picture by picture oriented as possible. Please if you have a better way of doing a certain step, feel free to comment. The biggest thing i have found is that most treads can tell you the "how", but don't actually SHOW you how it's done.
Tools you are going to need of this project:
Ratchet set, PB Blaster, Hammer (anything than be fixed with a hammer), torque bar that can handle up to 200 flbs (going to need 175 flbs), Flathead screwdriver ( a pretty stout one), Plyers and/or vise grip plyers, Breaker Bar, and Allen wrenches.
The sockets you need are: 9/16" 12 point, 5/8" 12 point, 1 11/16" 12 point (1 1/4" 12 point will work too and is what I used since I couldn't find a 1 11/16" in town), 3/8" to 1/2" adapter (unless you have a 1/2" ratchet), 1/2" to 1" adapter, and a 1/2" "3 extender.
And 6mm Allen wrench.
Removing the hub process:
First, before you lift the tire off the ground, remove the cotter pin from the center hub bolt and then break it lose with your 1 11/16" socket and breaker bar. You don't have to remove the bolt completely, but it's much easier to do it when the wheel isn't in the air. Then break lose the lug nuts, jack that tire off the ground, remove the lug nuts, and pull the tire off. Make sure the truck is in park and/or has wheel chalks. DON'T BE THAT GUY who lets his truck roll of the jack/jack stand. I personally lifted the entire front end and set it on stands so that i can turn the wheel when i need to because you will be moving it back and forth to get to certain bolts.
Pull the tire off and turn the wheel to the left (as if you are making a left turn). (I told y'all that this is literally going to be a step-by-step guide).
Locate these two bolts on the caliper (located on the top and bottom of the caliper, only bolts there that you need an allen wrench for).
Loosen these bolts with a 6mm allen wrench, but don't completely remove them.
(Now this next part may start some controversy. Everyone has there own way that they loosen the brakes in order to pull the caliper off. This is the way I do it and found it easiest.)
If you look, there are two oval shaped holes in the back of the caliper. Stick a flathead screwdriver onto the hole and try and slide it into one of the cooling vents in the rotor itself (the little square holes all around the rotor). Pry back SLOWLY on the screwdriver, it may take a little muscle. What you are trying to do is compress the pressure cups on the inside of the caliper (truck side of the caliper, but inside the caliper). You will feel it slowly give way as you pull. Some people like to open the lid on the brake fluid reservoir to keep from building up pressure, but I've done it without opening the reservoir before. Sometimes this is all that is needed to pull off the caliper, other times it takes more work. The point is to get the two "cups" in the brake caliper to push in. If you can loosen the caliper enough to work it partway off, you can slide the flathead down between the cup and the back of the brake pad and continue prying it back. be careful not to try and stab it or bend any parts, it just takes patience. DO NOT TRY TO PRY BETWEEN THE BRAKE PAD AND THE ROTOR. You will scratch the rotor and damage the pad itself.
If you have a better way of pulling the caliper off, please comment below and try throwing up a picture of it.
Once the caliper is off, place it on the control arm like so. The brake line is not long enough for it to sit on the ground and it is not a good idea to let it hang off the brake line. Don't try removing the line either unless you want brake fluid everywhere. There is no need to remove the line.
Remove the brake pads and little metal retaining clips. (My metal clips were shot in this picture so I went ahead and replaced them on both sides yesterday.) What you are left with is the bracket, rotor, and hub.
Next, you remove the bracket itself. It is held on with two bolts. These aren't normal bolts and actually require a special socket to remove, but i found that a 12 point 5/8" socket works just fine. Depending on how long these have been on the truck is most likely going to determine your "method" of taking them off. Mine weren't too bad since I just replaced this hub a month ago, but the seal blew so I had to replace it, again. :doh:
Once you get the bolts off, the bracket comes right off. I put the bolts partly back into the bracket just so i wouldn't lose them.
Next is the rotor itself. This a on a 2001 Dodge, so the rotor is separate of the hub assembly and pulls right off once you remove the bracket. All that is left is the hub itself.
Next, you can go ahead and remove this center bolt that you broke loose earlier. You don't have to wait til this step to remove it, but I like keeping it in order. Once you remove it, hit the bolt a few times with the hammer (lightly!). It should be able to slide back about an inch. If your hub is pretty rusty and been on there for a while, shoot some PB blaster all around the spindle there and let it soak in, then try hitting it again later on.
(Continued)
Discussion Starter · #2 · (Edited)
(Continued)
There are four bolts that are holding the hub on at this point. They are located in the recess of the knuckle, two on each side.
Using the 9/16" socket, 3" extender, and the ratchet, back the bolts out about halfway, or until the end of the bolt is flush with the front of the hub. Again, you may have to use a breaker bar to initially break the bolt loose and also PB blaster is your best friend.
Once you get ALL the bolts partly unscrewed, pull the ratchet off the socket and extender, but you will still need the socket and extender. Place the socket and extender (or just socket depending on which bolt) over the bolt and use the hammer to hit the socket/extender. DO NOT HIT THE BOLD DIRECTLY WITH THE HAMMER, USE THE SOCKET! If you try hitting the bolt with the hammer, you can bend/smash the teeth on the bolt and then wont be able to get the socket over the bolt again. I learned this the hard way :doh:. The hub is pretty much a press-fit into the knuckle and if it is rusted, it doesn't like to come out. (Use tons of PB blaster.) Hitting these bolts like this is the best way (I found) to get the hub to come out of the steering knuckle. Do this evenly, as soon as you see it slide a few millimeters, switch to a bolt on the opposite side and work it out evenly, or it won't come out.
This process may only take a few minutes, or if you are unlucky like me, an hour or two if it is extremely rusty.
Last step in removing the hub is the ABS sensor wire. This is relatively easy. Just unclip this wire from the brake line and pull it from the plastic mounts on the truck frame. The wire disconnect is located near the the turbo in the engine bay.
Congrats! You have removed a front wheel hub! :party018:
(as you can see, the seal in mine blew pretty badly)
Putting it back together is very simple
Pretty much doing everything you just did, but backwards.
Putting the Hub assembly back on:
First, go buy a new Hub at your local parts store or online. I bought mine from O'Riellys for around $235 (the aren't cheap). I like O'Riellys though because the one here near base has some of the best customer service. If you can find one with a lifetime or multi-year warranty, GET IT. The warranty is worth it. Mine only have a 1 year warranty and I regret not paying for a better hub/better warranty. Just my $.02.
While you are at the store, get some anti-seize for the bolts (You will thank yourself later if you ever have to replace the hub again). Run the ABS sensor wire through the dust shield FIRST and then line the hub up with the steering knuckle and the 4x4 spindle. You may want to grease the center part of the knuckle so that it is easier to slide the hub in. Then put the center hub bolt and washer back on hand tight.
Don't do this. I put the bracket back on before I put the rotor on :doh:.
Make sure you put the rotor on first before you put the bracket on. put some more anti-seize on the bolts as well.
Once you get the bracket back on, put the metal clips, brake pads, and then caliper back on. Make sure to put the brake pads back on the way that they came off or else they will most likely squeal. The caliper might be a b!tch to put back on, so you may need to press the cups in further in order to get it over the brake pads.
Next, put back in the screws for the caliper and tighten with the allen wrench. You will then hook the ABS sensor wire back up on all the little clips and run it back up into the engine bay where you will clip it back to the other wire.
Now you can go ahead and put the the wheel back on and tighten the lug nuts enough to be able to set the truck back down onto the wheel.
Lower the truck back down and tighten the lug nuts the rest of the way. Now all you have left is the center hub nut. The manual states that it to be tightened to 175 flbs. Do not over tighten this nut, or you will crush the seal inside the hub. If the pin holes do not line up with the nut, then back off the bolt until it does line up with the pin holes. Again, to each their own, but all this bolt is doing is holding the 4x4 shaft to the wheel. It's not holding the entire wheel assembly on. Also, it has the retaining cotter pin to keep the nut from undoing itself anyways.
Pop on that sexy Dodge hubcap again and you are good to go! :party018:
PM me or leave a comment if you have any questions or if you know a better way of doing a certain step. Or if you want to b!tch me out about how I "did it wrong", lol.
Thanks :zot:
Reactions: thepureface
awesome write up. two thing, why removing the caliper, i usually just pry it off between the bracket and the caliper, then i use a c-clamp to compress the caliper pistons.
the other, when you ever have to remove the hubs, take scotch brite and clean the bore out really really well. try to get it to shinny metal all the way around. you shouldnt have to worry about hurting the knuckle bore because the scotch brite isnt aggressive enough to remove enough material to hurt things. once you have it to shinny metal use lots, and lots of antiseize, i use the cat graphite base stuff, and then also coat the hub with a bunch as well. then install like normal.
next time you need to remove the hub it will come apart much easier, and i live in the rust belt.... had them pull out by hand on a couple trucks i used this method on..... i will never install one dry again.
also it looks like you may have an inner axle seal leak going on there as well....
they are fun to replace....
How lucky, you must have slip on rotors. Not so luck in 99.
Scotch bright is a good idea, I didn't even think about using it. I used grease from a grease gun when I was putting the new bearing in but anti-seize would probably be a better choice. I'm in Texas so i don't have to worry about rust too much. Also, all that oily substance on the u-joints and bottom of the knuckle is a mix of the grease that leaked (well poured) out of the old (new) hub that had a bad seal and Pb Blaster (kinda went crazy with the stuff). Axle is leaking though, but its out the differential casing.
Thanks! =)
(On my phone again btw)
Actually I take that back, it definitely does look like the axle is leaking as well doesn't it. Lol there is so many leaks on my truck atm I can't tell if its old or new. It definitely needs a lot of TLC. All part of the Dodge C.A.O.S. system, eh?
Lower carbon footprint than electric/new vehicles
Just for future reference the correct procedure(at least for 01's) is to align the hub nut slots with the cotter pin hope is to tighten the nut until it does. Also 01 and 02 spec is 180 ft-lbs.
Great write up and the pics really help. I’d respectfully suggest the OTC 6577 hub tool because I split both hubs in half removing them. That tool along with an electric impact made life way easier. Decided to just throw in a free spin kit since I’ll keep my old 2nd Gen forever.
1 - 13 of 13 Posts
