^^^^^ this.if you are in 4x4 and turning on dry pavement, you are begging something to break... all 4x4 will do the pop & hop in that situation...
?? what is a ball socket front shaft knuckle ??...It apparently shattered the ball socket in the knuckle on the front shaft.
oh no. i did wheel joints some time ago. front drive shaft. two piece. there is a knuckle with two joints and a ball socket in between. exploded mine:shots:?? what is a ball socket front shaft knuckle ??
do you mean a ujoint on the axleshaft?
ahhh, the front driveshaft CV joint!oh no. i did wheel joints some time ago. front drive shaft. two piece. there is a knuckle with two joints and a ball socket in between. exploded mine:shots:
from what i understand. dodge wont release parts to fix...so either build or buy.
