1 - 13 of 13 Posts
Hello,
I have a 1998 Dodge dually and for the life of me, I cant get the 4wd dash light to go off. Although when running down the road at speed, the light will flutter a bit. I have stopped and tried numerous different position of the shifter, but with no luck. Normally, I would not worry to much about this since I know its NOT in 4WD, BUT it messes with my Gear Vendor overdrive, so I need to get this fixed.
Is there a simple sending unit on the transfer case that can be replaced? Is it an easy replacement?
Thanks for the support!
Ken
The light switch is on the front axle in the CAD and is easy to get at and test.
Dang! What would I do without this site?!?!
Many an unfortunate soul have taken to driving a duraMax were it not for this site.
Are you hubs still enguaged? if so might be a vacuum issue... mine even stayed on once because something was frozen in CAD and went off once i left it in a heated shop overnight
Check and make sure the CAD is disengaged. If not there is a vacuum problem, it is froze or the accuator has stopped working. My 98 was NOT going into 4x4 so I opted to eliminate the CAD..
Check and make sure the CAD is disengaged. If not there is a vacuum problem, it is froze or the accuator has stopped working. My 98 wa NOT going into 4x4 so I opted to eliminate the CAD..
CAD? Not up on that acronym. Also, my 3500 does not have locking hubs, so I can rule that out. Thanks!
CAD= Center Axle Disconnect. Its the vacuum actuator that links your axles together to achieve 4x4. The picture above is the CAD unit.
Discussion Starter · #9 ·
Of course, I should have looked at that diagram again-What is the best/easiest way to know its disengaged?
What is odd is my 4WD light will stay off at lower speed, barely come on at around 35 and past that, its a solid light....
Raise the front axle off the ground and turn the wheels, if it turns the driveshaft turns = engaged.
Discussion Starter · #11 · (Edited)
Makes sense! Did some of the vintage Dodge's have locking hubs? Only reason I ask is a previous poster had said to make sure the hubs are turned. Thanks!
Makes sense! Did some of the vintage of Dodge's have locking hubs? Only reason I ask is a previous poster had said to make sure the hubs are turned. Thanks!
The 1st Gen trucks from 89' to 93' had the manual locking hubs.
He was probably saying the same thing.
1 - 13 of 13 Posts
