what exactly would I need?you could use tail hosuing and shaft out of two wheel drive into this trans just make sure you shim it right
2wd mainshaft, 2wd tailhousing, 2wd speedo gear components, yoke, tranny mount, and a complete teardown and rebuild of the transmission.what exactly would I need?
so it wouldn't be worth it...2wd mainshaft, 2wd tailhousing, 2wd speedo gear components, yoke, tranny mount, and a complete teardown and rebuild of the transmission.
I have the service manual with the rebuild section but it's not with me. how labor intense would that be, more than a days work?You would take apart your 2WD trans for the items bgilbert listed. Then tear down the $X$ trans and rebuild useing the listed 2WD parts when putting the trans back together.
