4th Gen Torque Specs
89689 Views 10 Replies 7 Participants Last post by  DodgeMech
hey guys, found this on another forum, figured id post it here so we dont have to go serching around...
Engine Torque Specs
(4th Gen RAM)
Air fuel control banjo screw (in pump)--------------------------------------------------------------9 ft lbs
Air fuel control fitting ( in head)---------------------------------------------------------------------6 ft lbs
Alternator ground cable mounting to block-------------------------------------------------------18 ft lbs
Alternator mounting to water pump inlet----------------------------------------------------------30 ft lbs
Alternator pulley--------------------------------------------------------------------------------------60 ft lbs
Alternator support (upper)---------------------------------------------------------------------------18 ft lbs
Battery cable ( negative) mounting to block------------------------------------------------------57 ft lbs
Belt tensioner mounting-----------------------------------------------------------------------------32 ft lbs
Block heater mounting--------------------------------------------------------------------------------9ft lbs
Cab heater hose clamp-------------------------------------------------------------------------------35 in lbs
Cab heater tubing clamp mounting----------------------------------------------------------------18 ft lbs
Camshaft thrust plate--------------------------------------------------------------------------------18 ft lbs
Clutch cover mounting to flywheel----------------------------------------------------------------17 ft lbs
Connecting rod (alternately tighten in 3 steps)
Step 1--------------------------------------------------------------------------------------------------22 ft lbs
Step 2--------------------------------------------------------------------------------------------------44 ft lbs
Step 3--------------------------------------------------------------------------------------------------60 ft lbs
Cooling fan mounting to fan clutch---------------------------------------------------------------15 ft lbs
Crossover clamp (air)-------------------------------------------------------------------------------44 in lbs
Cylinder head mounting bolts
1- All bolts--------------------------------------------------------------------------------------------66 ft lbs
2- long bolts-------------------------------------------------------------------------------------------89 ft lbs
3- tighten all bolts-------------------------------------------------------------------- additional 90 degrees
Exhaust manifold-------------------------------------------------------------------------------------32 ft lbs
Exhaust outlet pipe-v band clamp------------------------------------------------------------------72 in lbs
Exhaust pipe clamp mounting-----------------------------------------------------------------------20 ft lbs
Exhaust pipe steady rest mounting to trans--------------------------------------------------------50 ft lbs
Fan clutch mounting / fan hub (left hand threads)------------------------------------------------42 ft lbs
Fan hub bracket mounting---------------------------------------------------------------------------18 ft lbs
Fan hub bearing retaining cap screw---------------------------------------------------------------57 ft lbs
Fan pulley to fan hub-----------------------------------------------------------------------------------7 ft lbs
Fan pulley crankshaft----------------------------------------------------------------------------------7 ft lbs
Fan shroud mounting nuts---------------------------------------------------------------------------95 in lbs
Flywheel bolts---------------------------------------------------------------------------------------101 ft lbs
Flywheel housing adapter---------------------------------------------------------------------------44 ft lbs
Front engine mount isolator mounting to mount-------------------------------------------------80 ft lbs
Front engine mount through bolt-------------------------------------------------------------------30 ft lbs
Front engine mount to block------------------------------------------------------------------------44 ft lbs
Front oil filler pipe-access cover---------------------------------------------------------------hand tighten
Fuel banjo screw (in fuel pump)--------------------------------------------------------------------24 ft lbs
Fuel banjo screw (in head)---------------------------------------------------------------------------18 ft lbs
Fuel banjo screw (in injector)-------------------------------------------------------------------------6 ft lbs
Fuel filter-------------------------------------------------------------------------------half turn after contact
Fuel heater assembly mounting---------------------------------------------------------------------24 ft lbs
Fuel heater ground mounting to intake manifold--------------------------------------------------9 ft lbs
Fuel link fitting (high pressure)---------------------------------------------------------------------18 ft lbs
Fuel low pressure supple-----------------------------------------------------------------------------18 ft lbs
Fuel pump drive gear (with pump unlocked)------------------------------------------------------48 ft lbs
Fuel pump lock (bosch)------------------------------------------------------------------------------22 ft lbs
Fuel pump mounting mount-------------------------------------------------------------------------18 ft lbs
Fuel pump solenoid-----------------------------------------------------------------------------------32 ft lbs
Fuel pump support bracket--------------------------------------------------------------------------18 ft lbs
Fuel pump unlock (bosch)---------------------------------------------------------------------------10 ft lbs
Fuel vent screw (in banjo)-----------------------------------------------------------------------------6 ft lbs
Gear cover----------------------------------------------------------------------------------------------18 ft lbs
Gear housing - to - block-----------------------------------------------------------------------------18 ft lbs
Injector retaining nuts--------------------------------------------------------------------------------44 ft lbs
Intake manifold cover--------------------------------------------------------------------------------18 ft lbs
Intercooler attaching bolts---------------------------------------------------------------------------17 in lbs
Intercooler duct clamp nuts-------------------------------------------------------------------------72 in lbs
Lift pump mounting----------------------------------------------------------------------------------18 ft lbs
Lifting bracket (rear)---------------------------------------------------------------------------------57 ft lbs
Main bearing cap bolts
Step 1--------------------------------------------------------------------------------------------------45 ft lbs
Step 2--------------------------------------------------------------------------------------------------88 ft lbs
Step 3-------------------------------------------------------------------------------------------------129 ft lbs
Oil cooler assembly----------------------------------------------------------------------------------18 ft lbs
Oil fill tube bracket----------------------------------------------------------------------------------32 ft lbs
Oil filter--------------------------------------------------------------------------------3/4 turn after contact
Oil pan drain plug------------------------------------------------------------------------------------37 ft lbs
Oil pan mounting-------------------------------------------------------------------------------------18 ft lbs
Oil pressure regulating plug------------------------------------------------------------------------60 ft lbs
Oil pressure sender / switch------------------------------------------------------------------------12 ft lbs
Oil pump mounting----------------------------------------------------------------------------------18 ft lbs
Oil suction tube (flange)----------------------------------------------------------------------------18 ft lbs
Oil suction tube brace-------------------------------------------------------------------------------18 ft lbs
Power steering pump to vacuum pump mounting-----------------------------------------------18 ft lbs
Radiator hose clamp - upper------------------------------------------------------------------------35 in lbs
Radiator mounting nuts-----------------------------------------------------------------------------95 in lbs
Rear seal mounting-----------------------------------------------------------------------------------7 ft lbs
Refrigerant compressor lines - flange mounting------------------------------------------------15 ft lbs
Refrigerant compressor mounting-----------------------------------------------------------------35 ft lbs
Rocker lever nut------------------------------------------------------------------------------------ 18 ft lbs
Rocker support---------------------------------------------------------------------------------------18 ft lbs
Starter mounting-------------------------------------------------------------------------------------32 ft lbs
Starter battery (positive) cable nut-----------------------------------------------------------------16 ft lbs
Starter solenoid nut----------------------------------------------------------------------------------44 in lbs
Tappet cover / fuel drain line supports------------------------------------------------------------18 ft lbs
Thermistor---------------------------------------------------------------------------------------------18 ft lbs
Thermostat housing---------------------------------------------------------------------------------- 18 ft lbs
Throttle bracket mounting to mounting bracket--------------------------------------------------18 ft lbs
Throttle rod mounting to throttle lever nut-------------------------------------------------------7.5 ft lbs
Timing pin flange mounting------------------------------------------------------------------------44 in lbs
Torque converter access cover plate mounting---------------------------------------------------35 in lbs
Transfer case linkage bracket mounting / trans---------------------------------------------------30 ft lbs
Transfer case mounting to transmission-----------------------------------------------------------35 ft lbs
Trans cooler tubing mounting to oil pan flange---------------------------------------------------18 ft lbs
Trans kickdown cable bracket mounting / trans--------------------------------------------------50 ft lbs
Trans mount mounting to trans (manual)----------------------------------------------------------50 ft lbs
Trans mount through bolt mounting (manual)----------------------------------------------------50 ft lbs
Transmission mounting to engine------------------------------------------------------------------30 ft lbs
Transmission oil cooler line connection----------------------------------------------------------40 ft lbs
Transmission oil cooler line flange----------------------------------------------------------------50 in lbs
Transmission oil to air cooler hose clamps-------------------------------------------------------18 in lbs
Transmission to clutch housing mounting---------------------------------------------------------35 ft lbs
Transmission torque converter mounting----------------------------------------------------------35 ft lbs
Turbine housing----------------------------------------------------------------------------------------8 ft lbs
Turbo compressor housing clamp------------------------------------------------------------------75 in lbs
Turbo mounting nut----------------------------------------------------------------------------------24 ft lbs
Turbo oil drain tube----------------------------------------------------------------------------------18 ft lbs
Turbo oil supply (both ends)------------------------------------------------------------------------11 ft lbs
Vacuum pump mounting------------------------------------------------------------------------------7 ft lbs
Vacuum pump to gear housing mounting---------------------------------------------------------57 ft lbs
valve cover--------------------------------------------------------------------------------------------18 ft lbs
Vibration damper mounting-------------------------------------------------------------------------92 ft lbs
Water hose clamps----------------------------------------------------------------------------------- 35 in lbs
Water inlet connection-------------------------------------------------------------------------------32 ft lbs
Water pump mounting--------------------------------------------------------------------------------18 ft lbs
Water temperature sensor----------------------------------------------------------------------------37 ft lbs
Chassis Torque Specs
(4th Gen RAM)
Shock Absorber Upper Nut -------------------------------------------------------------------------40 ft lbs
Shock Absorber Lower Bolt -----------------------------------------------------------------------100 ft lbs
Shock Tower to Frame ------------------------------------------------------------------------------55 ft lbs
Lower Ball Joint Nut Initial Torque--------------------------------------------------------------- 35 ft lbs
Lower Ball Joint Nut Final Torque ---------------------------------------------------------------148 ft lbs
Upper Ball Joint Nut ---------------------------------------------------------------------------------70 ft lbs
Lower Control Arm Frame Nuts ------------------------------------------------------------------200 ft lbs
Lower Control Arm Axle Nut--------------------------------------------------------------------- 200 ft lbs
Upper Control Arm Frame Nuts ------------------------------------------------------------------120 ft lbs
Upper Control Arm Axle Nut ---------------------------------------------------------------------120 ft lbs
Stabilizer Bar Frame Bolt ---------------------------------------------------------------------------45 ft lbs
Stabilizer Link Axle Bracket---------------------------------------------------------------------- 110 ft lbs
Stabilizer Link Stabilizer Bar Nut -----------------------------------------------------------------27 ft lbs
Stabilizer Link Axle Bracket (Power Wagon)-------------------------------------------------- 110 ft lbs
Stabilizer Bar Nut (Power Wagon) ---------------------------------------------------------------110 ft lbs
Hub/Bearing Bolts ----------------------------------------------------------------------------------149 ft lbs
Axle Nut ---------------------------------------------132 ft lbs Beginning Torque, Then Rotate 5 to 10 ~ Times With a Final Torque of 263 ft lbs
Track Bar to Frame (2500/3500 4x4) ------------------------------------------------------------200 ft lbs
Track Bar to Axle (2500/3500 4x4) --------------------------------------------------------------200 ft lbs
Tie Rod End Nut -------------------------------------------------------------------------------------55 ft lbs
ABS Assembly Mounting Bolts -------------------------------------------------------------------11 ft lbs
ABS Assembly ABM Screws ----------------------------------------------------------------------31 in lbs
ABS Assembly Brake Line Fittings -------------------------------------------------------------170 in lbs
Dynamics Sensor-------------------------------------------------------------------------------------97 in lbs
Wheel Speed Sensors, Front Sensor Bolt -------------------------------------------------------190 in lbs
Wheel Speed Sensors, Bracket To Knuckle -----------------------------------------------------60 in lbs
Wheel Speed Sensors, Rear Sensor Stud-------------------------------------------------------- 200 in lbs
ABM Mounting Screws -----------------------------------------------------------------------------53 in lbs
RWAL Module Mounting Bolts -------------------------------------------------------------------11 ft lbs
RWAL Valve Brake Line Fittings ---------------------------------------------------------------170 in lbs
Rear Wheel Speed Sensor Mounting Bolt ------------------------------------------------------200 in lbs
Brake Booster Mounting Nuts ---------------------------------------------------------------------21 ft lbs
Master Cylinder Mounting Nuts -----------------------------------------------------------------160 in lbs
Reservoir Retaining Screws -------------------------------------------------------------------------6 ft lbs
Caliper Bleed Screws -------------------------------------------------------------------------------14 ft lbs
Caliper Mounting Pins, Front ----------------------------------------------------------------------24 ft lbs
Caliper Mounting Pins, Rear -----------------------------------------------------------------------22 ft lbs
Caliper Adapter Mounting Bolts, Front (1500) ------------------------------------------------130 ft lbs
Caliper Adapter Mounting Bolts, Front (2500/3500) -----------------------------------------275 ft lbs
Caliper Adapter Mounting Bolts, Rear (1500) -------------------------------------------------120 ft lbs
Caliper Adapter Mounting Bolts, Rear Upper (2500 and 3500) -----------------------------163 ft lbs
Caliper Adapter Mounting Bolts, Rear Lower (2500 and 3500) -----------------------------190 ft lbs
Junction Block Bolts, Front (1500) ----------------------------------------------------------------14 ft lbs
Junction Block Bolts, Rear (1500) -----------------------------------------------------------------18 ft lbs
Junction Block Bolts, Rear (2500/3500) ---------------------------------------------------------7.5 ft lbs
Brake Pedal Assembly Bracket Bolts (1500) -----------------------------------------------------23 ft lbs
Brake Pedal Assembly Bracket Nuts (2500/3500) -----------------------------------------------21 ft lbs
Support Plate Mounting Bolts/Nuts (1500) -------------------------------------------------------75 ft lbs
Support Plate Mounting Bolts/Nuts (2500/3500) ----------------------------------------------150 ft lbs
Brake Line Fittings, Master Cylinder -------------------------------------------------------------14 ft lbs
Brake Line Fittings, Junction Block (Both) ------------------------------------------------------14 ft lbs
Caliper Brake Line Banjo Bolt, Front -------------------------------------------------------------20 ft lbs
Caliper Brake Line Banjo Bolt, Rear --------------------------------------------------------------20 ft lbs
Brake Hose Bolts To Frame, Front ----------------------------------------------------------------7.5 ft lbs
Brake Hose Fitting -----------------------------------------------------------------------------------14 ft lbs
Parking Brake Pedal Assembly (1500) ------------------------------------------------------------18 ft lbs
Parking Brake Pedal Assembly (2500/3500) -----------------------------------------------------14 ft lbs
Hub/Bearing Bolts (1500) -------------------------------------------------------------------------120 ft lbs
Rotor to Hub Bolt, Rear (2500 and 3500 DRW) -----------------------------------------------114 ft lbs
Extension to Rotor Nut, Front (2500 and 3500 DRW) ----------------------------------------128 ft lbs
Hub/Bearing Bolts, Front (2500 and 3500 4X2) -----------------------------------------------130 ft lbs
Pitman Arm Gear Shaft Nut (2500, 3500) ------------------------------------------------------177 ft lbs
Drag Link to Pitman Arm (2500, 3500) ---------------------------------------------------------100 ft lbs
Drag Link to Tie Rod (2500, 3500) --------------------------------------------------------------100 ft lbs
Drag Link Adjuster Clamp (2500, 3500)--------------------------------------------------------- 40 ft lbs
Tie Rod End to Knuckle (2500, 3500) ------------------------------------------------------------78 ft lbs
Tie Rod End Adjuster Clamp (2500, 3500) ------------------------------------------------------40 ft lbs
Stabilizer Bar Link to Axle (2500, 3500) ---------------------------------------------------------50 ft lbs
Steering Damper to Axle or Linkage(2500, 3500) -----------------------------------------------75 ft lbs
Steering Damper Bracket U-Bolt Nuts (2500, 3500) --------------------------------------------45 ft lbs
Track bar to Axle - M16 fastener (2500, 3500) -------------------------------------------------200 ft lbs
Track Bar to Frame - M16 fastener (2500, 3500) ----------------------------------------------200 ft lbs
Lug Nut 9/16 X 18 with 60° Cone ---------------------------------------------------------------130 ft lbs
Lug Nut 9/16 X 18 with 60° Cone (2500, 3500 - SRW) --------------------------------------140 ft lbs
Lug Nut 9/16 X 18 with Flat Washer (3500 - DRW) ------------------------------------------145 ft lbs
Lug Nut 9/16 X 18 with Flat Washer (4500, 5500 - DRW) ----------------------------------148 ft lbs
Spare Tire Winch ------------------------------------------------------------------------------------15 ft lbs
Jounce Bumper Bolts ------------------------------------------------------------------------------21.5 ft lbs
Shock Absorber, Lower Nut/Bolt ----------------------------------------------------------------100 ft lbs
Shock Absorber, Upper Nut/Bolt ----------------------------------------------------------------100 ft lbs
Spring Clamp U-Bolt Nuts -----------------------------------------------------------------------110 ft lbs
Spring Front Nut/Bolt to Frame ----------------------------------------------------------------254.5 ft lbs
Spring Shackle Nut/Bolt, Upper/Lower --------------------------------------------------------160 ft lbs
Reactions: 5
1 - 11 of 11 Posts
Thank you:thumbsup::thumbsup:
Do you know where this info originated from? Is it from a Factory Service Manual or ?? Thanks for posting it up.
I'm not 100% of where it came from but in my opinion it does seems accurate. From information I had already known, it does seem to match up with what was posted, therefore it makes me feel like it is accurate. With that said I'm not saying it is 100% accurate, it may be and it may not by type thing. Also if anyone does know of any mistakes please post them for everyone to see and I can edit the original text.
Thanks
Good information to have. Thank you!
maybe this could be made into a sticky?
I'm not sure how to make it into a sticky
Torques:
Oil Drain Plug.....37 ft/lbs
Manual Transmission G56 Fill Plug 42 ft/lbs and Drain Plug 42 ft/lbs
Transfer Case NV271 Fill Plug 15-25 ft/lbs and Drain Plug 15-25 ft/lbs
Transfer Case NV273 Fill Plug 15-25 ft/lbs and Drain Plug 15-25 ft/lbs
___________________________
The above was copied & pasted from the 2010-2012 sticky. One thing I noticed was the above listed oil drain plug at 60 foot pounds, and per what I copied was 37 ft/lbs. I do think that most of the above is correct, but sure would not hurt to double check before torqueing down things. Just a thought.
Ok, good to know. I wasn't sure how accurate everything was, I just saw it on another forum and couldn't find one on here so figured I'd share it.
Thanks
^^^ Excellent find. Always good to pass things on.
Sounds like 12 valve stuff to me...for one thing, the cr co..rods are 22, 44, then 60 degrees...and all the headbolts are the same length...also, there are two M6 bolts that hold the injectors, that take 10lb/ft...60 would break them in half...
1 - 11 of 11 Posts
