1 - 3 of 3 Posts
https://www.ebay.com/itm/NEW-DODGE-2500-3500-POWER-WAGON-17-POLISHED-FACTORY-WHEELS-RIMS-4-2011-17-2498/273181976423?hash=item3f9aea2767:g:vCkAAOSw1EhZkhEX:rk:3:pf:0
I found these Power Wagon rims on Ebay, obviously. Wanting them because A. They look killer B. Give me the ability to run 35x12.50's without rubbing or adding any other mods (due to slightly different backspacing than the factory 3rd gens).
Two questions:
The center opening for the hub looks extra small...is that just me? Will our large hubs fit through there without machining?
What center caps/lug nuts would you recommend? I know the lug nuts are different between the two generations and this center cap is much smaller then what is on my factory 3rd gen steel wheels.
Thank you in advance.
I have 18inch 2015 Laramie 6 spoke on my 08' with no problems with the hub size. Can't comment on the center caps but with the lug nuts I went cheap off ebay and they rust quick
1 - 3 of 3 Posts
