1 - 2 of 2 Posts
Is it possible to monitor these through PIDS? I'm trying to diagnose my injectors and knowing which PIDS I need would be supremely helpful. Thanks!
It is not possible to monitor return rates for the injectors, only balance rates which unfortunately do not tell you whether you're dumping fuel into the cylinder or it's being returned to the tank... only way to really get an accurate return rate test is to pull the injectors and have them tested on a test stand at full pressure (around 26,000 PSI)....
1 - 2 of 2 Posts
