21 - 38 of 38 Posts
Sub'd. I'd be very interested in a slightly more plug and play version of this. I miss my chevy mirrors.
Thanks and yes I have thought about it and I'm currently looking for the dodge plugs to use instead of having to go to the dealer. I also have figured out how to make amd machine a replacement mounting bracket for the ones I bought is will be an easy swap and use the dodge bolt holes and the chevy cover but you may have to still trim for the little tabs. As long as life dont get in the way I'm hoping to have working models in about 2 months. As long as I can find the correct plugs.
Nice work on the mirrors, I know there was a lot of 4th Gen interest on the thread where we did the swap on the 3rd Gens. That wiring looks quite a bit more complicated than what I had to go through. I did install resistors on mine as well so the running lights in the housing would double as blinkers too.
Congrats that looks like a really clean job!!
Great write up thanks for taking the time to do it. I would be interested in some as well. I will be subscribing to the thread and waiting for any updates.
Thanks for taking the time to do this.
I did this mod to my 2017 Ram 2500. Like the OP said, no more blind spots. It took me a couple of hours to get this done, but so worth it. I did not drill any new holes on the doors, just had to oblong one of them. All the modifications were done to the mirror bases. Anyone wanting to do this, be prepared for aluminum dust everywhere and lots of cutting and grinding to make them fit right. It’s totally doable on a 4th gen. Thanks for the right up and wiring schematic! None of my wire colors matched, but I used the numbering of the plugs.
Discussion Starter #27
Looks awesome. And yes it is really time consuming and the wiring is a pita that's why I made sure I posted for mine but I'm sure from 11 to 17 they changed the color code and probably the plug as well. I guess once enough of us do this the after market world will see and start making a plug and play version. I have thought about it and it would not be that hard to make a new pedestal to go from the chevy mirror to the ram door. But I couldnt do it cost effective enough with buying a set of mirrors and having to change that part. Youd be looking at 250 to 350 for a set not to mention the wiring would be a nightmare as well being I can not find where to get oem ram plug to wire onto the chevy mirrors.
Those look GREAT!!!
Would you mind posting a closer up pick on how the mirror bezel meets up with the door frame??
Did you run into the same problem as the OP with direction? Meaning up down left and right when controlling?
Where did you buy the mirrors?
Thanks guys! Here are more pics of the mirror. I accidentally broke the tab on the hinge cover of the driver side mirror when I took it apart, but I have a replacement on order. You can see the only hole I had to oblong is the one towards the front of the truck to get the bezel to line up vertically with the window frame. I will be putting in some black vinyl to cover up the paint between mirror and window gasket.
Also added pics of the blinkers and the corner led running lights. I have the white led hooked up to the puddle, but I’m thinking of wiring them to cargo lights to turn on at anytime. These are super bright and might work for tailgaters with their high beams on. I also drilled a 1/8” hole for the temp sensor. It sits right next to the mirror hinge and probe is exposed for accurate temps.
I took a 600 mile drive recently and these are night and day compared to stock, easily one of the best mods I’ve done. I can honestly say that Ram should’ve put these style mirrors from the factory.
Yes, up and down work correctly, but left and right are backwards. It really doesn’t bother me at all since they don’t need constant adjusting.
I bought the mirrors from eBay. I can’t post links yet, but search for “For 14 15 16 17 18 Chevy GMC Power+Heated Smoke Signal Tow Mirrors Pair”.
Those little backup LED's aren't going to do anything for tailgaters. They hardly light up the side of the truck let alone anything behind or to the side of the truck. They are bright but they really don't throw any useful light anywhere. I wired mine up to my reverse light switch, I really don't need them for anything other than a "warning" to others when I'm backing up.
Now the OEM Chevy mirrors if you can get ahold of them, those are said to actually do their job (the little reverse light LED's)...
I'm one of the original 3rd genners that did this mod. Still one of the best things I've done to my truck. I wired the running/puddle light to also be a blinker. The way the third gens are at least, there are 2 separate wires for running and blinker. I tied both of them to the puddle light power and put a resistor in-line with the running light power so it's a bit more dim than "normal". Then, when the blinker supplies power to that light, it will flash brighter each blink since the blinker power is at full force (no resistor). Works out pretty slick to have the running lights double as the blinker.
Glad to see this mod has taken off for the 4th gen, back when we did this there were a few who were thinking about it but worried the door card was too shallow and too much material would have to be removed from the mount for it to still be structural.
I laughed at "This is what Ram should have done from the factory...". Ha I don't think Dodge is going to start doing OEM Chevy parts anytime soon.
If you look at the brand new Chevy's though, their mirrors are hideous. Glad we'll have plenty of options up through '17 at least for mirror parts if we need them.
LOL! What I meant was, Ram should have designed their own style of these type of vertical mirrors like Ford and Chevy.
Another plus is losing the whistling from the stock mirrors. I was going crazy trying to find what that noise was and when I swapped these out it was gone.
Oh yea I agree on that one!
My buddy has the same year truck as me (04.5) and he's got the stock mirrors. When we go bike we shuttle trucks to the top for some runs. It was my turn to shuttle and I have been so used to my mirror swap, I was trying to see out his OEM mirrors and you just realize how spoiled you are with the swap after you hop back in someone else's truck that have OEM...
The back two bolts on the mirror base line up with the holes on the door ? Only one you had to make modifications is the one closest to the front ?
Discussion Starter #36
Yeah they should line up I drilled new holes due to I didnt want to have a miss match on my vent visors. Due to who ever put them before I bought the truck installed them to high on the door.
I've been following the 3rd gen GM mirror thread for awhile now. I'm in the process of putting GM mirrors on my 07, but for the 4th Gen people, it looks like there's a plug and play option now.
Wow that's pretty cool, a company finally did it!
21 - 38 of 38 Posts
