1 - 3 of 3 Posts
Recently bought a 96 2500 and 4 high works but when i go to shift it in 4 low the rear drive shaft shakes back and forth like it doesn’t want to fully engage. Any ideas?
Inside the transfer case one shift fork shifts high and low range. The other shifts two wheel drive and four wheel drive. Sounds like a problem with the range shift fork. Also what transfer case 241dld or 241dhd. The 241dld has a snapring in the rear of transfer case that can break causing the shaft to walk back and forth causing damage to the shift fork.
Check the shift linkage for. Adjustment or a worn bushing. May be not be fully pulling it into gear.
1 - 3 of 3 Posts
