will the 727 gas trans bolt to the cummins engine or was the diesel trans different
I don't think so, and if it did you wouldnt want to go that root. Gas trans dont hold up under the low end torque that a diesel has. They smoke the TC alot, they can break input shafts too.
The 727 behind the Cummins was a "LoadFlite" as opposed to a "TorqueFlite". It had a different front end on it, and a few internal modifications as well to better handle the torque.
well im just going w the 4bt bc my truck has sissy axles and im more concered w fuel mileage than anything that gasser trans dont cost nothing to rebuild just had it done and the only weight i pull is a 3500 pound boat i was hoping there was some way to mate them so i could keep 4 wheel drive and speedo just throw in a motor and go. so does the diesel trans use an adaptor plate to mate to the cummins
Heres a couple places that you can try. Fordcummins.com destroked.com, Acmeadapters.com, Phoenix Casting & Machining, Inc. - Home.
I dont think that you will be happy with it. Gas engines get there torque about 3000rpms and diesel get there torque between 1500 and 1800. And info from cummins they draw my 3.9 down to 1300rpms to make 373lbs of torque. The low end torque of a diesel is what tears them up.
DieselAutoPower.com
The gasser transmission bellhousing is smaller than the cummins as well. You'll need a different transmission.
